P1194
Manufacturer Specific Definitions for P1194
Audi | Fuel pressure control valve - short to positive |
Citroen | ECU A/D Converter |
Daewoo | Ets Limphome Tps2 Pos. Mal. |
Dodge | HO2S Insufficient Transition Time Ratio Bank 2 Sensor 1 |
Ford | Engine Control Unit A/D Converter |
Hyundai | Limp Home-TPS2 Position Malfunction |
Jaguar | Oxygen sensor heater cylinders 1, 2, 3, 4, 5, 6 - resistance |
Jeep | Heated oxygen sensor (H02S), heater control -circuit malfunction |
Kenworth | P1194 - Indicates that the fuel filter is very clogged |
Kia | Limp-home solenoid – signal malfunction |
Land Rover | Oxygen sensor heater 2 – cylinders 1, 2, 3, 4, 5, 6 – heater resistance |
Peterbilt | P1194 - Indicates that the fuel filter is very clogged |
Peugeot | ECU A/D Converter |
Ram | Heated oxygen sensor (H02S), heater control -circuit malfunction |
Volkswagen | Fuel pressure control valve - short to positive |
