P1190
Manufacturer Specific Definitions for P1190
Audi | Heated oxygen sensor (HO2S) 1, Bank 1, reference voltage - range/performance problem |
Bmw | Throttle control system – incorrect air flow |
Buick | Engine Vacuum Leak |
Cadillac | Engine Vacuum Leak |
Chevrolet | Engine Vacuum Leak |
Chrysler | Turbocharger (TC) boost pressure sensorvoltage high |
Citroen | Calibration Resistor Out Of Range |
Daewoo | Throttle Actuator Crct Fault |
Dodge | Fuel pressure control solenoid -malfunction |
Ford | Calibration Resistor Out Of Range |
Freightliner | Fuel pressure control solenoid -malfunction |
Gm | Engine Vacuum Leak |
Hyundai | Intake Throttle Actuator-Malfunction |
Jaguar | Oxygen sensor heater cylinders 1, 2, 3, 4, 5, 6 - low resistance |
Jeep | Throttle Inlet Pressure Sensor High |
Kia | Intake Throttle Actuator Malfunction |
Land Rover | Oxygen sensor heater 1 – cylinders 1, 2, 3, 4, 5, 6 – heater resistance low |
Mini | Pre-Catalyst Fuel Trim System Bank 1 |
Peugeot | Calibration Resistor Out Of Range |
Volkswagen | Heated oxygen sensor (HO2S) reference voltage - range/performance problem |
