P1189
Manufacturer Specific Definitions for P1189
Audi | Linear O2 Sensor Compensation Resistor Short to B+ |
Bmw | Mass air flow (MAF)/vane air flow (VAF) – flow too low |
Buick | Engine oil pressure warning lamp switchcircuit malfunction |
Cadillac | Engine oil pressure waming switch -circuit malfunction |
Chevrolet | Engine oil pressure warning lamp switch circuit malfunction |
Chrysler | Turbocharger (TC) boost pressure sensor-voltage low |
Citroen | Pump Speed Signal Fault |
Dodge | Turbocharger (TC) boost pressure sensor voltagelow |
Ford | Pump Speed Signal Fault |
Gm | Engine Oil Pressure Switch Fault |
Hyundai | Governer Deviation |
Jaguar | Oxygen sensor heater cylinders 1, 2, 3, 4, 5, 6 - low resistance |
Jeep | Throttle Inlet Pressure Sensor Low |
Kia | Fuel Pressure Monitoring - Governor Deviation at Engine speed Too high |
Land Rover | Fuel trim (FT), bank 2 – adaptation |
Mini | Fuel Control Bank 2 Sensor 1 |
Peugeot | Pump Speed Signal Fault |
Pontiac | Engine oil pressure warning lamp switch -circuit malfunction |
Saturn | Engine Oil Pressure Switch Fault |
Volvo | System too rich, bank 2 -signal malfunction |
Volkswagen | Linear O2 Sensor Compensation Resistor Short to B+ |
We have not gotten around to publishing a technical guide specifically for P1189 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
