P1187
Manufacturer Specific Definitions for P1187
Acura | Fuel Tank Temperature Sensor Circuit Low Voltage |
Audi | Heated oxygen sensor (HO2S) 1, Bank 1 or 2 - circuit malfunction |
Bmw | Secondary air injection (AIR), pump relay – signal low |
Buick | Engine Oil Temperature Sensor Circuit Low Voltage |
Cadillac | Engine Oil Temperature Sensor Circuit Low Voltage |
Chevrolet | Engine oil temperature (EOT) sensor -voltage low |
Chrysler | Turbocharger (TC) boost pressure sensorrange/performance problem |
Citroen | Variant Selection |
Dodge | Fuel rail pressure (FRP) sensor -malfunction |
Ford | Variant Selection |
Freightliner | Fuel rail pressure (FRP) sensor -malfunction |
Gm | Engine Oil Temperature Sensor Circuit Low Voltage |
Honda | Fuel tank temperature sensor- low input |
Hyundai | Fuel Pressure Monitoring - Regulator Valve Stuck |
Jaguar | Oxygen sensor heater cylinders 1, 2, 3, 4, 5, 6 - circuit malfunction |
Jeep | Throttle Inlet Pressure/MAP Correlation |
Kia | Fuel Pressure Monitoring - Regulator Valve Stick |
Land Rover | Oxygen sensor heater 1 – cylinders 1, 2, 3, 4, 5, 6 – circuit malfunction |
Mini | O2 Sensor Heater Control Circuit Bank 2 Sensor 2 |
Peugeot | Variant Selection |
Volvo | System too lean, bank 2 – full load |
Volkswagen | Heated oxygen sensor (HO2S) circuit malfunction |
Hi. Thank you for your answer
Please say me The P1187 Fault Location in my “peugeot 206” automobile.
