P1177
Reading P1177 on your car
P1177 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1177
AudiLambda correction after catalyst, Bank 2 - control limit reached
BmwCarbon Canister Shut Off Valve Control Circuit Electrical
CitroenSynchronization Fault
DaewooEts Motor - Short /Gnd 2
FordSynchronization Fault
HyundaiETS Motor Open Short #2
JaguarRich mixture - long term fuel trim
KiaElectronic throttle system (ETS), throttle motor – circuit 2 malfunction
Land RoverFuel trim (FT) rich mixture
Mercedes-BenzEngine oil sensor, quality/level/temperature – malfunction
MiniO2 Sensor Slow Response Bank 2
PeugeotSynchronization Fault
VolvoSystem too lean, bank 1 – full load
VolkswagenLambda correction after catalyst, control limit reached
We have not gotten around to publishing a technical guide specifically for P1177 yet.
