P1175
Manufacturer Specific Definitions for P1175
Bmw | Heated Catalyst Current Too High During Heating Bank 1 |
Buick | Heated oxygen sensor (H02S) 1, bank 2 mixture variation between cylinders |
Cadillac | Heated oxygen sensor (H02S) 2, bank 2 mixture variation between cylinders |
Chevrolet | Heated oxygen sensor (H02S) 1, bank 2 mixture variation between cylinders |
Citroen | Cam Control Fault |
Daewoo | Ets Valve Stuck - Closed 2 |
Ford | Cam Control Fault |
Gmc | Heated oxygen sensor (H02S) 1, bank 2 mixture variation between cylinders |
Gm | Fuel Trim Cylinder Balance Bank 2 |
Hummer | Heated oxygen sensor (H02S) 1, bank 2 mixture variation between cylinders |
Hyundai | ETS Valve Stuck-Close#2 |
Kia | Electronic throttle system (ETS), closed throttle – range/performance problem |
Land Rover | System too rich, bank 2 |
Mini | Fuel Trim Adaptation Additve Bank 2 Malfunction |
Oldsmobile | Fuel Trim Cylinder Balance Bank 2 |
Peugeot | Cam Control Fault |
Pontiac | Heated oxygen sensor (H02S) 1. bank 2 – mixture variation between cylinders |
Saab | Fuel trim, bank 2 -adapted value out of range |
Saturn | Heated oxygen sensor (H02S) 1. bank 2 mixture variation between cylinders |
Suzuki | Lambda Controller Limit Malfunction Bank 2 Too Lean |
Volvo | System too rich, bank 1 – full load |
Volkswagen | Pre-Injection Switched Off |
We have not gotten around to publishing a technical guide specifically for P1175 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
