P1174
Manufacturer Specific Definitions for P1174
Acura | AF Sensor 21 Circuit Out Of Range High |
Audi | Fuel measurement system, Bank 1 - injection timing incorrect |
Bmw | Heated Catalyst Battery Voltage or Current too Low During Heating Bank 1 |
Buick | Heated oxygen sensor (H02S) 1, bank 1 mixture variation between cylinders |
Cadillac | Heated oxygen sensor (H02S) 1, bank 1 mixture variation between cylinders |
Chevrolet | Heated oxygen sensor (H02S) 1, bank 1 mixture variation between cylinders |
Citroen | Cam Sensor Fault |
Daewoo | Ets Valve Stuck - Closed 1 |
Ford | Cam Sensor Fault |
Gmc | Heated oxygen sensor (H02S) 1, bank 1 mixture variation between cylinders |
Gm | Fuel Trim Cylinder Balance Bank 1 |
Honda | Heated oxygen sensor (H02S) 2, bank 2 – out of range, high |
Hummer | Heated oxygen sensor (H02S) 1, bank 1 mixture variation between cylinders |
Hyundai | ETS Valve Stuck-Close#1 |
Isuzu | Fuel Trim Cylinder Balance |
Kia | Electronic throttle system (ETS), closed throttle – range/performance problem |
Land Rover | System too lean, bank 2 |
Mini | Fuel Trim Adaptation Additve Bank 1 Malfunction |
Oldsmobile | Fuel Trim Cylinder Balance Bank 1 |
Peugeot | Cam Sensor Fault |
Pontiac | Heated oxygen sensor (H02S) 1, bank 1 – mixture variation between cylinders |
Saab | Fuel trim, bank 1 -adapted value out of range |
Saturn | Heated oxygen sensor (H02S) 1. bank 1 mixture variation between cylinders |
Suzuki | Lambda Controller Limit Malfunction Bank 2 Too Rich |
Volvo | System too lean, bank 1 -full load |
Volkswagen | Fuel measurement system, injection timing incorrect |
Soo….what’s the fix for gm
