P1171
Manufacturer Specific Definitions for P1171
Acura | Fuel system - mixture lean under acceleration |
Audi | Throttle motor position sensor 2 - range/performance problem |
Bmw | Knock sensor(s) (KS) - circuit malfunction |
Buick | Fuel system -lean during acceleration |
Cadillac | Fuel System Lean During Acceleration |
Chevrolet | Fuel system -lean during acceleration |
Citroen | Rotor Sensor Fault |
Daewoo | Fuel trim, under load – mixture too lean |
Ford | Rotor Sensor Fault |
Gmc | Fuel system -lean during acceleration |
Gm | Fuel System Lean During Acceleration |
Honda | Heated oxygen sensor (H02S) 1 – circuit malfunction |
Hyundai | ETS Valve Stuck-Open |
Isuzu | Fuel trim – mixture too lean during acceleration |
Jaguar | Weak mixture - cylinders 1, 2, 3, 4, 5, 6 |
Kenworth | P1171 - AFC correction minimum limits have been reached. System may be running lean. |
Kia | Electronic throttle system (ETS), WOT – malfunction |
Land Rover | System too lean, bank 1 |
Mini | Ambient Pressure Sensor Learned Value Error |
Oldsmobile | Heated oxygen sensor (H02S) 1 -voltage low |
Opel | Mixture control (MC),engine under load - mixture lean |
Peterbilt | P1171 - AFC correction minimum limits have been reached. System may be running lean. |
Peugeot | Rotor Sensor Fault |
Pontiac | Fuel system -lean during acceleration |
Saab | Fuel system – lean during acceleration |
Saturn | Fuel system -lean during acceleration |
Suzuki | Fuel Supply System Lean During Power Enrichment |
Volvo | System too lean, bank 1 – part load |
Volkswagen | Throttle motor position sensor 2 - range/ performance problem |
