P1168
Reading P1168 on your car
P1168 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1168
AcuraAir/Fuel Ratio Sensor Label Low Voltage
AudiMass air flow (MAF) sensor, Bank 2 - low input
CitroenFuel Rail Sensor In-Range Low Failure
DaewooO2s Heater Pwr(B1/S2)
FordFuel Rail Pressure Sensor Condition Low Pressure
HondaHeated oxygen sensor (H02S) -front -low voltage
HyundaiHeated Oxygen Sensor (HO2S) Heater Power-B1/S2
InfinitiClosed loop control LH – inoperative
KenworthP1168 - Indicates that leak flow restriction is blocked
KiaHeated oxygen sensor (H02S), heater- rear, bank 1 – circuit malfunction
LincolnFuel rail pressure sensor -signal low
MazdaFuel rail pressure sensor- signal low
MercuryFuel rail pressure sensor -signal low
NissanClosed loop control – bank 2 – inoperative
PeterbiltP1168 - Indicates that leak flow restriction is blocked
PeugeotFuel Rail Sensor In-Range Low Failure
We have not gotten around to publishing a technical guide specifically for P1168 yet.
