P1167 – Air/Fuel Ratio Sensor 1 Heater System Malfunction (ACURA, HONDA)
Jessica Howe
By Jessica Howe (Contact Me)
Last Updated 2019-09-30
ASE Mechanic
P1167 P1167 – Air/Fuel Ratio Sensor 1 Heater System Malfunction (ACURA, HONDA)
Manufacturer Specific Definitions for P1167
AcuraAir fuel (A/F) sensor - RSX 1 - heater system malfunction
AudiMass air flow (MAF) sensor, Bank 2 - range/performance problem
ChryslerCapacitor Voltage 1
CitroenInvalid Test,throttle not depressed
DaewooOxygen sensor (02S) 1, bank 1 – rich in deceleration fuel cut-off
DodgeCapacitor Voltage 1
HondaHeated oxygen sensor (H02S)- front- heater circuit malfunction
HyundaiHeated Oxygen Sensor (HO2S)(B2) Adaptation
InfinitiHeated oxygen sensor (H02S) 2, bank 2 – voltage high
IsuzuFuel trim, bank 1 – mixture too rich during deceleration
JeepCapacitor Voltage 1
KenworthP1167 - Indicates warning of leak flow restriction is blockage
KiaHeated oxygen sensor (H02S) – front, bank 2 – control limit
NissanHeated oxygen sensor (H02S) 2, bank 2 – maximum voltage monitoring
PeterbiltP1167 - Indicates warning of leak flow restriction is blockage
PeugeotInvalid Test,throttle not depressed
SuzukiHO2S11 Rich In Decel Fuel Cutoff
VolvoElectronic throttle system (ETS) – signal malfunction
VolkswagenMass Air Flow Sensor 2 Unplausible Signal
  1. What Does Code P1167 Mean?
  2. Where is the P1167 sensor located?
  3. What are the common causes of code P1167?
  4. How expensive is it to fix code P1167?
  5. What are the symptoms of code P1167?
  6. What are common solutions to code P1167?
  7. How serious is code P1167?
  8. How difficult is it to repair code P1167?
  9. How do you troubleshoot code P1167?
  10. Codes Related to P1167
  11. Get Help with P1167
The P1167 diagnostic troubleshooting code is manufacture specific. Every manufacture will have a different meaning or fault associated with the code. That being said, nearly all P1167 codes across all manufactures have something to do with the air/fuel mixture and the oxygen sensors that monitor how well the vehicle is being driven. European models may differ from this, and you will need to look up the DTC for that specific manufacture for a more accurate description of what the code may mean for your model.
For Honda and Accura, a P1167 code stands for a heater system malfunction in the air/fuel ratio sensor 1. The air/fuel ratio sensor monitors the amount of oxygen in the exhaust fumes exiting the engine. This allows the vehicle’s powertrain control module to adjust the fuel/air ratios to achieve maximum efficiency. These sensors are heated when needed in order to start making correct readings as soon as possible. A P1167 code indicates that the heating system is not working.
There are two air/fuel ratio sensors (or oxygen sensors) on most modern vehicles.  They are relatively the same, but perform different functions for the engine. The air/fuel ratio sensor 1 is located on the exhaust under the vehicle between the engine and the catalytic converter. The heater system for the sensor is built into it, and is not serviceable on its own. Transaxle models may have the air/fuel ratio sensor 1 located towards the top of the engine compartment, making it easier to access.
  • Failing Heated Air/Fuel Ratio Sensor 1
  • Air/Fuel Ratio Sensor 1 Circuit Malfunction
Under $100
  • Check engine light
  • Reduced gas mileage
  • Lack of acceleration
The most common repair to resolve this code is to replace the air/fuel ratio sensor 1. New sensors come with the appropriate wiring connectors, which should also eliminate any wiring issues on that side of the circuit’s connector.
The vehicle may perform differently with a P1167, but it is not likely to cause a serious issue while driving or prevent you from operating the vehicle.
If the air/fuel ratio sensor 1 simply needs to be replaced, it is easy to do at home with the right socket. Most air/fuel ratio sensors require a special attachment for a ratchet that will compensate for the sensor’s cord.
A P1167 DTC (diagnostic troubleshooting code) indicates that there is an issue with the heated air/fuel ratio sensor. This is either due to an issue with the sensor itself, the heating element in the sensor, or the sensor’s electrical circuit. A visual inspection can tell you if there is obvious damage to the sensor or its electrical wiring.
  • P1162: Air/Fuel Ratio Sensor 1 Circuit Malfunction
  • P1166: Heater System Electrical Problem
  • P1135: Air/Fuel Ratio Sensor Heater Circuit Malfunction Bank 1 Sensor 1 (Toyota)
