P1163
Manufacturer Specific Definitions for P1163
Acura | Air fuel (A/F) sensor - RSX 1 - slow response |
Audi | Fuel temperature sensor - open circuit/short to positive |
Bmw | Misfire During Start Cylinder 12 |
Buick | HO2S Bank 2 Sensor 3 Lean System Or Low Voltage |
Cadillac | HO2S Bank 2 Sensor 3 Lean System Or Low Voltage |
Chevrolet | HO2S Bank 2 Sensor 3 Lean System Or Low Voltage |
Gm | HO2S Bank 2 Sensor 3 Lean System Or Low Voltage |
Honda | Heated oxygen sensor (H02S)- front- range/performanceproblem |
Infiniti | Heated oxygen sensor (H02S) |
Kenworth | P1163 - Transmission output shaft speed out of range |
Land Rover | Heated oxygen sensor (H02S), too rich, bank 2 – circuit malfunction |
Mercedes-Benz | Engine oil level switch – malfunction |
Mini | Fuel Trim Additve Per Ignition Bank 1 High |
Nissan | Heated oxygen sensor (H02S) 1, bank 2 – lean shift monitoring |
Peterbilt | P1163 - Transmission output shaft speed out of range |
Volkswagen | Fuel temperature sensor - open circuit/short to positive |
