P1162
Reading P1162 on your car
P1162 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1162
| Make | Fault Location |
| Acura | Air fuel (A/F) sensor - RSX 1 - circuit malfunction |
| Audi | Fuel temperature sensor - short to ground |
| Bmw | Misfire Cylinder 11 With Fuel Cut-Off |
| Daewoo | High Prss Pump / Fuel Line Mal |
| Honda | Heated oxygen sensor (H02S) – front – circuit malfunction |
| Hyundai | High Pressure Pump&Fuel Line |
| Kenworth | P1162 - TCO1 message vehicle speed out of range fault |
| Land Rover | Heated oxygen sensor (H02S), too weak, bank 1 – circuit malfunction |
| Mercedes-Benz | Throttle position (TP) sensor(s)- malfunction |
| Mini | Fuel Trim Additve Per Ignition Bank 1 Low |
| Peterbilt | P1162 - TCO1 message vehicle speed out of range fault |
| Volkswagen | Fuel temperature sensor - short to ground |
We have not gotten around to publishing a technical guide specifically for P1162 yet.
