P1160
Manufacturer Specific Definitions for P1160
Audi | Intake air temperature (IAT) sensor - short to ground |
Bmw | Misfire Cylinder 10 With Fuel Cut-Off |
Chrysler | Ignition Voltage |
Dodge | Ignition Voltage |
Genesis | Key Off Duration Implausible Short |
Jeep | Ignition Voltage |
Kenworth | P1160 - Rear Axle LH Wheel Speed out of range fault |
Mini | Fuel Trim Additve Bank 2 Low |
Nissan | Turbocharger (TC) wastegate pressure sensor – circuit malfunction |
Peterbilt | P1160 - Rear Axle LH Wheel Speed out of range fault |
Saab | Throttle actuator control (TAC)- return spring failure |
Subaru | Throttle actuator control (TAC) – return spring failure |
Volkswagen | Intake air temperature (IAT) sensor - short to ground |
We have not gotten around to publishing a technical guide specifically for P1160 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
greetings…
my car peugeot 407 2010 petrol gives out p1160….car idling very rough….earlier other codes refer to O2 sensor heater n high voltage present…car can still run …the only problm then i need to start the car n waited for 3-4 minutes until idling speed stable at around 700rpm. i bought new 02 sensor n the error codes for O2 cleared but still have to wait a few minutes before idling stablize…..then new codes came in p1160….i removed the throttle body incl the cable n clean it with carborator cleaner n refixed.
when i start the car…then it happen…this time the idling speed shoot up to 1200++ rpm n stay there….the idling became rough n pressing the pedal did not increase the speed in tandem with the pedal pressed.
tried to reset the ecu by removing the battery n dscharge the positive side as well…several time….still the same…
then i noticed ( using torque apps n obd2 plug) when starting up the car idling is around 1000++ n slowly reduce to around 900++ rpm…but as soon as coolant temp hit 56 deg C , triangle warning light came out n idling speed shoot up to 1200++ rpm with rough n noisy engine…….did it several times n as soon coolant temp hit 56deg….it happened……of course the car cannot be driven….
any idea or suggestion…..
sorry for a lengthy story….?aznin
Hi sorry I know its an old post but was wondering if you got it sorted, as I have the same problem with my 2008 peugeot. also ew10a engine
Amigo, tenho um peugeot 308 2.0que deu esse mesmo código e depois de algumas pesquisas descobri que o defeito era o diafragma da tampa de válvula!
Comprei uma tampa nova e tive meu problema resolvido! Espero que ajude com essa dica!
Boa sorte!
Disculpa en donde se localiza esa pieza que cambiaste, tendrás imágenes de favor
