P1159
Manufacturer Specific Definitions for P1159
Acura | Air/Fuel Ratio Sensor 1 AFS+ Terminal Low Voltage |
Audi | Mass air flow (MAF) sensor, Bank 1 & 2 - implausible ratio |
Bmw | Misfire Cylinder 8 With Fuel Cut-Off |
Buick | HO2S Cross Counts Bank 2 Sensor 2 |
Cadillac | HO2S Cross Counts Bank 2 Sensor 2 |
Chevrolet | HO2S Cross Counts Bank 2 Sensor 2 |
Chrysler | Improper Start Attempt |
Citroen | Fuel Stepper Motor Malfunction |
Daewoo | Variable Intake Device Mal |
Dodge | Improper Start Attempt |
Gm | HO2S Cross Counts Bank 2 Sensor 2 |
Honda | Heated oxygen sensor (H02S) – front – circuit low voltage positive terminal |
Hyundai | Variable Induction System |
Jeep | Improper Start Attempt |
Kenworth | P1159 - Front Axle RH Wheel Speed out of range fault |
Kia | Intake manifold air control actuator – circuit malfunction |
Mini | Fuel Trim Additve Bank 1 High |
Peterbilt | P1159 - Front Axle RH Wheel Speed out of range fault |
Peugeot | Fuel Stepper Motor Malfunction |
Volkswagen | Mass air flow (MAF) sensor, implausible ratio |
We have not gotten around to publishing a technical guide specifically for P1159 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
