P1158
Manufacturer Specific Definitions for P1158
Acura | Air/Fuel Ratio Sensor 1 Terminal Low Voltage |
Audi | Manifold absolute pressure (MAP) sensor - range/performance problem |
Buick | HO2S Bank 2 Sensor 2 Rich Or High Voltage |
Cadillac | Heated oxygen sensor (H02S) 2, bank 2 -not switching, fuel trim (FT) rich mixture |
Chevrolet | Heated oxygen sensor (H02S) 2, bank 2 -not switching, fuel trim (FT) rich mixture |
Citroen | Lack Of HO2S22 Switch - Sensor Indicates Rich |
Ford | Lack of O2 Switches Bank 2 Sensor 2 Indicates Lean |
Gm | HO2S Bank 2 Sensor 2 Rich Or High Voltage |
Honda | Heated oxygen sensor (H02S) – front- circuit low voltage negative terminal |
Jaguar | Heated oxygen sensor (HO2S) cylinders 4, 5, 6 - indicates rich |
Kenworth | P1158 - Front Axle LH Wheel Speed out of range fault |
Land Rover | Heated oxygen sensor (H02S) 2 -cylinders 4,5, 6 – mixture rich |
Lincoln | Heated oxygen sensor (H02S) 2, bank 2 -not switching, fuel trim (FT) rich mixture |
Mazda | Heated oxygen sensor (H02S) 2, bank 2 – rich mixture indicated |
Mercury | Heated oxygen sensor (H02S) 2, bank 2 not switching, fuel trim (FT) rich mixture |
Peterbilt | P1158 - Front Axle LH Wheel Speed out of range fault |
Peugeot | Lack Of HO2S22 Switch - Sensor Indicates Rich |
Porsche | Engine Compartment Temperature |
Volvo | Heated oxygen sensor (H02S) 2, bank 2- rich |
Volkswagen | Manifold absolute pressure (MAP) sensor - range/performance problem |
