P1157
BAT Team
Manufacturer Specific Definitions for P1157
AcuraAir/Fuel Ratio Sensor 1 Range/Performance Problem
AudiManifold absolute pressure (MAP) sensor - supply voltage
BmwMisfire During Start Cylinder 8
BuickHO2S Bank 2 Sensor 2 Lean System Or Low Voltage
CadillacHeatetl oxygen sensor (H02S) 2, bank 2 -not switching, fuel trim (FT) weak mixture
ChevroletHO2S Bank 2 Sensor 2 Lean System Or Low Voltage
CitroenLack Of HO2S22 Switch - Sensor Indicates Lean
FordLack of O2 Switches Bank 2 Sensor 2 Indicates Lean
GmHO2S Bank 2 Sensor 2 Lean System Or Low Voltage
HondaHeated oxygen sensor (H02S) – H02S 1 – circuit malfunction
JaguarHeated oxygen sensor (HO2S) cylinders 4, 5, 6 - indicates lean
Land RoverHeated oxygen sensor (H02S) 2 – cylinders 4,   5, 6 – mixture lean
LincolnHeated oxygen sensor (H02S) 2, bank 2 -not switching, fuel trim (FT) weak mixture
MazdaHeated oxygen sensor (H02S) 2, bank 2 – lean mixture indicated
MercuryHeated oxygen sensor (H02S) 2, bank 2 not switching, fuel trim (FT) weak mixture
MiniO2 Sensor Heater Circuit High Voltage Bank 2 Sensor 2
PeugeotLack Of HO2S22 Switch - Sensor Indicates Lean
PorscheEngine Compartment Temperature
VolvoHeated oxygen sensor (H02S) 2, bank 2 -lean
VolkswagenManifold absolute pressure (MAP) sensor - supply voltage
We have not gotten around to publishing a technical guide specifically for P1157 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
