P1156
Reading P1156 on your car
P1156 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1156
AudiManifold absolute pressure (MAP) sensor - open circuit/short to ground
BmwMisfire Cylinder 7 With Fuel Cut-Off
BuickHO2S Rich Average Bank 2 Sensor 1
CadillacHO2S Rich Average Bank 2 Sensor 1
ChevroletHO2S Rich Average Bank 2 Sensor 1
ChryslerFuel Rail Pressure Malfunction Plausibility
CitroenFuel Select Switch Malfunction
FordFuel Selector Switch Circuit
GmHO2S Rich Mean Bank 2 Sensor 1
LincolnEngine control module (ECM)/fuel injector control module -malfunction
MercuryEngine control module (ECM)/fuel injector control module -malfunction
MiniO2 Sensor Heater Circuit Low Voltage Bank 2 Sensor 2
PeugeotFuel Select Switch Malfunction
VolkswagenManifold absolute pressure (MAP) sensor - open circuit/short to ground
We have not gotten around to publishing a technical guide specifically for P1156 yet.
