P1153
Manufacturer Specific Definitions for P1153
Acura | Heated oxygen sensor (HO2S) - LH front - insufficient switching |
Audi | Heated oxygen sensor (HO2S) 2, Bank 1 & 2 - interchanged |
Bmw | Misfire Cylinder 6 With Fuel Cut-Off |
Buick | Heated oxygen sensor (H02S) 1, bank 2 insufficient switching |
Cadillac | Heated oxygen sensor (H02S) 1, bank 2insufficient switching |
Chevrolet | Heated oxygen sensor (H02S) 1, bank 2insufficient switching |
Chrysler | Fuel Rail Pressure Malfunction Negative Deviation Fuel Pressure Solenoid Setpoint |
Citroen | Bank 2 Fuel Control Shifted Lean |
Dodge | Fuel Rail Pressure Malfunction Negative Deviation Fuel Pressure Solenoid Setpoint |
Ford | Bank 2 Fuel Control Shifted Lean |
Gmc | Heated oxygen sensor (H02S) 1, bank 2insufficient switching |
Gm | HO2S Insufficient Switching Bank 2 Sensor 1 |
Honda | Heated oxygen sensor (HO2S) - LH front - insufficient switching |
Hummer | Heated oxygen sensor (H02S) 1, bank 2 insufficient switching |
Hyundai | Accelerator Pedal Position Sensor (APS) Circuit-High Input (EMS) |
Isuzu | Heated oxygen sensor (HO2S) - LH front - insufficient switching |
Jeep | Fuel Rail Pressure Malfunction Negative Deviation Fuel Pressure Solenoid Setpoint |
Kia | Accelerator pedal position (APP) sensor – high input |
Lexus | Heated oxygen sensor (H02S) – RH front – response malfunction |
Mazda | Fuel trim (FT) lean mixture – bank 2 |
Mini | O2 Sensor Heater Circuit High Voltage Bank 2 Sensor 1 |
Oldsmobile | Heated oxygen sensor (H02S) 1, bank 2insufficient switching |
Peugeot | Bank 2 Fuel Control Shifted Lean |
Pontiac | Heated oxygen sensor (H02S) 1. bank 2 – insufficient switching |
Saab | Heated oxygen sensor (H02S) 1, bank 2 – insufficient switching |
Saturn | Heated oxygen sensor (H02S) 1, bank 2 insufficient switching |
Scion | Air/Fuel Ratio Sensor Circuit Response Malfunction Bank 2 Sensor 1 |
Subaru | Heated oxygen sensor (H02S) 1, bank 1 – range/performance problem voltage high |
Toyota | Air fuel sensor - California - RH front - response malfunction |
Volvo | Heated oxygen sensor (H02S) 1, bank 2 – no signal |
Volkswagen | Heated oxygen sensor (HO2S) interchanged |
