P1152
Manufacturer Specific Definitions for P1152
Audi | Long term fuel trim 2, Bank 1 - below lean limit |
Bmw | Misfire During Start Cylinder 6 |
Chevrolet | Heated oxygen sensor (H02S) 1, bank 2 signal circuit shorted to heater circuit |
Chrysler | Fuel Rail Pressure Malfunction Positive Deviation Fuel Pressure Solenoid Setpoint |
Citroen | Lack Of HO2S21 Switch - Sensor Indicates Rich |
Dodge | Fuel Rail Pressure Malfunction Positive Deviation Fuel Pressure Solenoid Setpoint |
Ford | Lack of Upstream Heated Oxygen Sensor Switch Sensor Indicates Rich Bank 2 |
Hyundai | Accelerator Pedal Position Sensor (APS) Circuit-Low Input (EMS) |
Jeep | Fuel Rail Pressure Malfunction Positive Deviation Fuel Pressure Solenoid Setpoint |
Kia | Accelerator pedal position (APP) sensor – low input |
Land Rover | Heated oxygen sensor (H02S), upstream, bank 2 – mixture too rich |
Lincoln | Heated oxygen sensor (H02S) 1, bank 2 -not switching, fuel trim (FT) rich mixture |
Mazda | Heated oxygen sensor (H02S) – LH or front bank – front (6 cyl) – rich mixture indicated |
Mercury | Heated oxygen sensor (H02S) 1, bank 2 not switching, fuel trim (FT) rich mixture |
Mini | O2 Sensor Heater Circuit Low Voltage Bank 2 Sensor 1 |
Peugeot | Lack Of HO2S21 Switch - Sensor Indicates Rich |
Saab | Heated oxygen sensor (H02S) 1, bank 1 -range/ performance problem voltage low |
Subaru | Heated oxygen sensor (H02S) 1, bank 1 – range/performance problem voltage low |
Suzuki | Heated oxygen sensor (H02S) 1, bank 2 – heater control – circuit high |
Volvo | Heated oxygen sensor (H02S) 1, bank 2 – signal high |
Volkswagen | Long term fuel trim below lean limit |
