P1146
Reading P1146 on your car
P1146 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1146
AudiMass air flow (MAF) sensor, Bank 1 - supply voltage
DaewooIdle Co Potentiomet
HyundaiIdle CO Potentiometer
InfinitiHeated oxygen sensor (H02S) 2, bank 1 – voltage low
Mercedes-BenzMass air flow (MAF) sensor(s)- malfunction
NissanHeated oxygen sensor (H02S) 2, bank 1 – minimum voltage monitoring
SaabManifold absolute pressure (MAP) sensor – range/performance problem voltage high
SubaruManifold absolute pressure (MAP) sensor – range/performance problem voltage high
VolkswagenMass air flow (MAF) sensor - supply voltage
We have not gotten around to publishing a technical guide specifically for P1146 yet.
