P1144
Manufacturer Specific Definitions for P1144
Audi | Mass air flow (MAF) sensor, Bank 1 - open circuit/short to ground |
Buick | HO2S Bank 1 Sensor 3 Rich Or High Voltage |
Cadillac | HO2S Bank 1 Sensor 3 Rich Or High Voltage |
Chevrolet | HO2S Bank 1 Sensor 3 Rich or High Voltage |
Chrysler | Fuel Rail Pressure Malfunction Positive Volume Deviation |
Citroen | Air Assist Control Valve Circuit Malfunction |
Daewoo | Fuel Cut Sol V/V |
Dodge | Fuel Rail Pressure Malfunction Positive Volume Deviation |
Gm | HO2S Bank 1 Sensor 3 Rich or High Voltage |
Hyundai | Slow Cut Solenoid Malfunction |
Infiniti | Heated oxygen sensor (H02S) 1, bank 1 – voltage high |
Jeep | Fuel Rail Pressure Malfunction Positive Volume Deviation |
Mazda | Heated oxygen sensor (H02S) 2, bank 1 – rich mixture indicated |
Nissan | Heated oxygen sensor (H02S) 1, bank 1 – rich shift monitoring |
Peugeot | Air Assist Control Valve Circuit Malfunction |
Saab | Manifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor – range/ performance problem voltage high |
Subaru | Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor- range/performance problem voltage high |
Volkswagen | Mass air flow (MAF) sensor - open circuit/ short to ground |
We have not gotten around to publishing a technical guide specifically for P1144 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
