P1143
Manufacturer Specific Definitions for P1143
Audi | Load calculation - too high |
Buick | HO2S Bank 1 Sensor 3 Lean Or Low Voltage |
Cadillac | HO2S Bank 1 Sensor 3 Lean Or Low Voltage |
Chevrolet | HO2S Bank 1 Sensor 3 Lean System or Low Voltage |
Chrysler | Fuel Rail Pressure Malfunction Positive Pressure Deviation |
Citroen | Air Assist Control Valve Range/Performance |
Daewoo | Feed Back Sol V/V Mal |
Dodge | Fuel Rail Pressure Malfunction Positive Pressure Deviation |
Gm | HO2S Bank 1 Sensor 3 Lean System or Low Voltage |
Infiniti | Heated oxygen sensor (H02S) 1, bank 1 – voltage low |
Jeep | Fuel Rail Pressure Malfunction Positive Pressure Deviation |
Mazda | Heated oxygen sensor (H02S) 2, bank 1 – lean mixture indicated |
Nissan | Heated oxygen sensor (H02S) 1, bank 1 – lean shift monitoring |
Peugeot | Air Assist Control Valve Range/Performance |
Saab | Manifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor – range/ performance problem voltage low |
Subaru | MAP/BARO sensor – range/performance problem voltage low |
Volkswagen | Load calculation - too high |
I’m getting repeated P1143 on my 2002 Nissan Xterra. I usually get some odd code every year when it gets cold…then goes away when the weather warms up, so thought that here,…but we’re now into 40’s and 50’s in Maryland and P1143 is back. Any more experience from anybody on Xterra’s, old ones (my baby! 🙂
