P1140
Manufacturer Specific Definitions for P1140
Audi | Heated oxygen sensor (HO2S) 2, Bank 2 - heater resistance too high |
Bmw | Misfire Cylinder 1 With Fuel Cut-off |
Buick | HO2S Transition Time Ratio Bank 1 Sensor 2 |
Cadillac | Heated oxygen sensor (H02S) 2, bank 1 slowresponse |
Chevrolet | HO2S Transition Time Ratio Bank 1 Sensor 2 |
Chrysler | Vacuum Reservoir Solenoid Circuit Condition |
Citroen | Water In Fuel Condition |
Daewoo | Intake Air Temp. Sensor |
Daihatsu | Throttle motor drive circuit fault, short circuit |
Dodge | Vacuum Reservoir Solenoid Circuit Condition |
Ford | Water In Fuel Condition |
Gm | HO2S Transition Time Ratio Bank 1 Sensor 2 |
Hyundai | Rationality Check-Throttle Position Sensor (TPS), Mass Air Flow (MAF) Sensor |
Infiniti | Camshaft position (CMP) actuator LH – circuit malfunction |
Jeep | Vacuum Reservoir Solenoid Circuit Condition |
Lamborghini | Load calculation cross check |
Lincoln | Water In Fuel Condition |
Mercury | Water In Fuel Condition |
Mini | Mass or Volume Air Flow Circuit Range/Performance Problem |
Nissan | Camshaft variable valve timing sensor – bank 1 – range/performance problem |
Oldsmobile | Heated oxygen sensor (H02S) 2, bank 1 slow response |
Peugeot | Water In Fuel Condition |
Porsche | Load Signal |
Saab | Heated oxygen sensor (H02S) 1, bank 2, heater – range/performance problem |
Subaru | Heated oxygen sensor (H02S) 1, bank 2, heater – range/performance problem |
Volkswagen | Heated oxygen sensor (HO2S) heater resistance too high |
