P1134
Manufacturer Specific Definitions for P1134
Acura | Heated oxygen sensor (HO2S) - RH front - slow operation |
Audi | HO2S Heater Circuit- Bank 1 & 2 Sensor 2 Short To B+ |
Bmw | 'B' Camshaft Position Plausibility |
Buick | Heated oxygen sensor (H02S) 1 -slowresponse |
Cadillac | Heated oxygen sensor (H02S) 1, bank 1 slow response |
Chevrolet | Heated oxygen sensor (H02S) 1, bank 1 -slow response |
Citroen | HO2S Transition Time Ratio Sensor 1 |
Daewoo | Oxygen sensor (02S) 1, bank 1 -transition ratio |
Dodge | ECT Sensor Circuit Intermittent High Voltage |
Gmc | Heated oxygen sensor (H02S) 1, bank 1 slow response |
Gm | HO2S Transition Time Ratio Bank 1 Sensor 1 |
Honda | Heated oxygen sensor (HO2S) - RH front - slow operation |
Hummer | Heated oxygen sensor (H02S) 1, bank 1 slow response |
Hyundai | Heated Oxygen Sensor (HO2S)-B1/S1 |
Isuzu | Heated oxygen sensor (HO2S) - RH front - slow operation |
Kenworth | P1134 - WRAF heater CJ125 short-circuit to ground fault for heater diagnostic |
Kia | Heated oxygen sensor (H02S)- front, bank 1 – signal malfunction |
Mack | Aftertreatment Hydrocarbon Air Purge Valve: Open Circuit |
Mahindra | Under Voltage Error For Egr Valve H-Bridge |
Mazda | Fuel trim (FT) rich mixture – bank 1 |
Mini | O2 Sensor Heater Circuit Signal Intermittent Bank 1 Sensor 2 |
Oldsmobile | Heated oxygen sensor (H02S) 1, bank 1 slow response |
Peterbilt | P1134 - WRAF heater CJ125 short-circuit to ground fault for heater diagnostic |
Peugeot | HO2S Transition Time Ratio Sensor 1 |
Pontiac | Heated oxygen sensor (H02S) 1, bank 1 – slow response |
Saab | Heated oxygen sensor (H02S) 1, bank 1 – slow response |
Saturn | Oxygen sensor (02S)/heated oxygen sensor (H02S) 1, bank 1, slow response |
Subaru | Engine control module (ECM) |
Suzuki | HO2S11 Transition Ratio |
Volkswagen | HO2S Heater Circuit- Bank 1 & 2 Sensor 2 Short To B+ |
We have not gotten around to publishing a technical guide specifically for P1134 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
