P1129
Manufacturer Specific Definitions for P1129
Acura | Manifold absolute pressure (MAP) sensor - pressure higher than expected |
Audi | Long term fuel trim, entire speed/load range, Bank 2 - system too rich |
Chrysler | Closed loop fuel control not achieved -bank 2 |
Citroen | Downstream Heated O2 Sensors Swapped |
Daewoo | Second Lock Solenoid Mal |
Daihatsu | Emergency home abnormal 1 |
Dodge | Heated oxygen sensor (H02S) 1, bank 2 signal error |
Ford | Downstream Oxygen Sensors Swapped from Bank to Bank |
Honda | MAP sensor – signal higher than expected |
Hyundai | 2nd Lock Solenoid Malfunction |
Isuzu | Manifold absolute pressure (MAP) sensor - pressure higher than expected |
Jeep | Closed loop fuel control not achieved -bank 2 |
Land Rover | Heated oxygen sensors (H02S) 1 – sensors transposed |
Lexus | Throttle actuator control (TAC) system- malfunction |
Lincoln | Heated oxygen sensor (H02S) 2, bank 1/ bank 2 -interchanged |
Mazda | Heated oxygen sensor (H02S)- rear- bank 1/bank 2 sensors transposed |
Mercury | Heated oxygen sensor (H02S) 2, bank 1/ bank 2 -interchanged |
Mitsubishi | Closed Loop Fueling Not Achieved Bank 2 |
Peugeot | Downstream Heated O2 Sensors Swapped |
Porsche | Oxygen Sensing |
Ram | Heated oxygen sensor (H02S) 1, bank 2 signal error |
Saturn | Manifold absolute pressure (MAP) sensor signal high |
Toyota | Throttle actuator control (TAC) system - malfunction |
Volkswagen | Long term fuel trim, system too rich |
