P1124
Manufacturer Specific Definitions for P1124
Audi | Long Term Fuel Trim Adjustment Bank 1 System Too Lean |
Bmw | Ignition system diagnostic monitor, cylinder 2 – duration too short |
Citroen | Throttle Position Sensor Out Of Self Test Range |
Daewoo | Idle Ratio (Idling)-Lean |
Daihatsu | TPS(self learn) |
Ford | Throttle Position Sensor Out of Self-Test Range |
Hyundai | Fuel System Lean-Idle |
Infiniti | Throttle motor – short circuit |
Lamborghini | Long term fuel trim adaptive air system high |
Land Rover | Throttle position (TP) sensor- voltage high |
Lincoln | Throttle position (TP) sensor -signal malfunction |
Mazda | Throttle position (TP) sensor – out of self-test range |
Mercury | Throttle position (TP) sensor -signal malfunction |
Mini | Differential Pressure Sensor Intake Manifold Adaptation |
Nissan | Throttle valve position motor relay – short circuit |
Peugeot | Throttle Position Sensor Out Of Self Test Range |
Porsche | Oxygen Sensing |
Saab | Traction control signal – voltage high |
Subaru | Traction control signal – voltage high |
Volvo | Engine control module (ECM) – internal malfunction |
Volkswagen | Long Term Fuel Trim Adjustment Bank 1 System Too Lean |
We have not gotten around to publishing a technical guide specifically for P1124 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
