P1123
Manufacturer Specific Definitions for P1123
Audi | Long Term Fuel Trim Adjustment Bank 1 System Too Rich |
Bmw | Ignition system diagnostic monitor, cylinder 1 – duration too short |
Citroen | Throttle Position Sensor In Range But Higher Than Expected |
Daewoo | Timing Pos Snsr Mal |
Ford | Throttle Position Sensor Circuit Intermittent High Voltage |
Hyundai | Fuel System Rich-Idle |
Infiniti | Throttle motor relay – circuit malfunction |
Lamborghini | Long term trim adaptive air system low |
Land Rover | Throttle position (TP) sensor – voltage low |
Lexus | Coolant Flow Control Valve Position Sensor Circuit High |
Lincoln | Throttle Position Sensor Circuit Intermittent High Voltage |
Mazda | Throttle position (TP) sensor – stuck open |
Mercury | Throttle Position Sensor Circuit Intermittent High Voltage |
Mini | Pedal Position 1 High Input |
Peugeot | Throttle Position Sensor In Range But Higher Than Expected |
Porsche | Oxygen Sensor Heating |
Toyota | Coolant Flow Control Valve Position Sensor Circuit High |
Volkswagen | Long Term Fuel Trim Adjustment Bank 1 System Too Rich |
P1123 code for ashok Leyland van
