P1119
Manufacturer Specific Definitions for P1119
Audi | Heated oxygen sensor (HO2S) 1, Bank 2 - heater short to ground |
Buick | Engine Coolant Temperature Signal Out Of Rage |
Cadillac | Engine Coolant Temperature Signal Out Of Rage |
Chevrolet | Engine Coolant Temperature Signal Out Of Rage |
Citroen | Manifold Absolute Temperature Circuit High Input |
Daewoo | Inlet Metering Valve Control |
Dodge | ECM -internal fault |
Ford | Manifold Absolute Temperature Circuit High Input |
Freightliner | ECM -internal fault |
Gm | Engine Coolant Temperature Signal Out Of Rage |
Hyundai | Inlet Metering Valve Control |
Infiniti | Engine coolant temperature (ECT) sensor, radiator – circuit malfunction |
Nissan | Engine coolant temperature (ECT) sensor – circuit malfunction |
Peugeot | Manifold Absolute Temperature Circuit High Input |
Porsche | Oxygen Sensor Heating |
Volvo | Manifold absolute pressure (MAP) sensor/mass air flow (MAF) sensor, adaptation – range/performance problem, higher limit |
Volkswagen | Heated oxygen sensor (HO2S) heater short to ground |
