P1117
P1117 | HO2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 2 (AUDI, VOLKSWAGEN) Mass Or Volume Air Flow Circuit Low Input Bank 2 (BMW, MINI) Engine Coolant Temperature Signal Out-Of-Range Low (BUICK, CADILLAC, CHEVROLET, GMC) Engine Coolant Temperature Sensor Intermittent (FORD, LINCOLN, MAZDA, MERCURY) HO2S Circuit Low Voltage Bank 1 Sensor 2 (KIA) Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage System (LEXUS, SCION, TOYOTA) |
Other Manufacturer Specific Definitions for P1117
Engine Coolant Temperature Sensor Intermittent (Ford)Engine Coolant Temperature Signal Out-Of-Range Low (GM)
Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage System (Toyota)
Heated oxygen sensor (HO2S) heater short to ground (Volkswagen)
Heated oxygen sensor (HO2S) 2, Bank 1 - heater short to ground (Audi)
Engine torque difference Bank 1 to 2 - malfunction (BMW)
Engine Coolant Temperature Signal Out-Of-Range Low (Buick)
Engine Coolant Temperature Signal Out-Of-Range Low (Cadillac)
Engine Coolant Temperature Signal Out-Of-Range Low (Chevrolet)
ECM -internal fault (Dodge)
ECM internal fault (Freightliner)
HO2S Circuit Low Voltage Bank 1 Sensor 2 (Kia)
Radiator outlet engine coolant temperature (ECT) - low input (Land Rover)
Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage System (Lexus)
Engine coolant temperature (ECT) sensor/cylinder head temperature (CHT) sensor circuit intermittent (Lincoln)
Engine coolant temperature (ECT) sensor – intermittent sensing (Mazda)
Engine coolant temperature (ECT)sensor/cylinder head temperature (CHT) sensorcircuit intermittent (Mercury)
Mass Or Volume Air Flow Circuit Low Input Bank 2 (Mini)
Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage System (Scion)
Barometric pressure (BARO) sensor -signal high (Volvo)
BAT Team Discussions for P1117
- Dodge Intrepid code
We need mileage and engine and year. Any other codes ? What is repair and tune up history? If it is the cat bad they are under federal warranty for 80k or 8 years. But one of the main causes of cat codes is bad tune up or engine miss or running rich. Also sometimes there is a pcm reflash for the pro... - 99 Suburban 5.7 OBDII code P0430
Code does not say replace or the cat or o2 sensors are bad. How is the tune up. Engine miss or runing rich is the leading cause of cat code? http://www.troublecodes.net/articles/catfailure/ A little info on cat codes. :) DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P... - PO430- 98 Explorrer 4.0L SOHC 2WD
[quote="ScottVA"] My wife was driving my truck and was on some ice and someone pushed her into a pole. She hit the pole on the drivers' side from the front of the wheel well flare to the gas filler door. She didn't hit very hard- mostly scs along the quarter panel. Anyway, after this incident, the C... - 01 Pontiac Sunfire P0420
Engine running rich or not right or missfire is the main cause of cat codes. And sometimes 02 sensors. http://www.troublecodes.net/articles/catfailure/ A little more info. :) DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicate bank one catalyst syste... - 1998 Dodge grand Caravan trouble codes
One of the main causres of cat codes is bad tune up missfires anfd rich exhaust. How many miles on you last tune up? Kev-2 posted a good link. Here is a little to add to it. :) DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicate bank one catalyst syste...
Leave a Reply
