P1116
Manufacturer Specific Definitions for P1116
Acura | Engine Coolant Temperature Sensor Performance Problem |
Audi | Heated oxygen sensor (HO2S) 1, Bank 1 - heater open circuit |
Bmw | Charge Air Pressure Actuator Short Circuit To Ground |
Buick | Engine Coolant Temperature Sensor Signal Unstable Or Intermittent |
Cadillac | Engine Coolant Temperature Sensor Signal Unstable Or Intermittent |
Chevrolet | Engine coolant temperature (EeT) sensor circuit malfunction |
Citroen | Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range |
Daewoo | Booster Pressure Snsr - Gnd/Open |
Ford | Engine Coolant Temperature Sensor is Out of Self-Test Range |
Gm | Engine Coolant Temperature Sensor Signal Unstable Or Intermittent |
Honda | Engine coolant temperature (ECT) sensor – range/performance problem |
Hyundai | Boost Pressure Sensor-Malfunction. |
Land Rover | Engine coolant temperature (ECT) sensor – range/performance problem |
Lexus | Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage System |
Lincoln | Engine coolant temperature (ECT) sensor/cylinder head temperature (CHT) sensor out of self-test range |
Mazda | Engine coolant temperature (ECT) sensor- out of self-test range |
Mercury | Engine coolant temperature (ECT) sensor/cylinder head temperature (CHT) sensorout of self-test range |
Mini | Mass Or Volume Air Flow Circuit Range/Performance Problem Bank 2 |
Peugeot | Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range |
Saab | Engine torque control cut signal – voltage low |
Scion | Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage System |
Subaru | Engine torque control cut signal – voltage low |
Suzuki | Engine coolant temperature (ECT) – circuit performance |
Toyota | Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage System |
Volvo | Barometric pressure (BARO) sensor -signal low |
Volkswagen | Heated oxygen sensor (HO2S) heater open circuit |
We have not gotten around to publishing a technical guide specifically for P1116 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
