P1114
Manufacturer Specific Definitions for P1114
Acura | Engine coolant temperature (ECT) sensor - circuit/ intermittent voltage low |
Audi | Heated oxygen sensor (HO2S) 2, Bank 1 - heater resistance too high |
Buick | Engine coolant temperature (ECT) sensorcircuit malfunction -voltage low |
Cadillac | Engine coolant temperature (ECT) sensor circuit malfunction -voltage low |
Chevrolet | Engine coolant temperature (ECT) sensor voltage low, intermittent |
Citroen | Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input |
Daewoo | Engine coolant temperature (ECT) sensor- intermittent voltage low |
Dodge | MAP Sensor Circuit Intermitten Hi Voltage |
Ford | Intake Air Temperature Sensor 2 Circuit Low |
Genesis | Engine coolant temperature (ECT) sensor – signal malfunction |
Gmc | Engine coolant temperature (ECT) sensor voltage low, intermittent |
Gm | Engine Coolant Temperature Sensor Circuit Intermittent Low Voltage |
Honda | Engine coolant temperature (ECT) sensor - circuit/ intermittent voltage high |
Hummer | Engine coolant temperature (ECT) sensor voltage low, intermittent |
Hyundai | Engine Coolant Temp Low |
Isuzu | Engine coolant temperature (ECT) sensor- circuiUintermittent voltage low |
Kia | Engine coolant temperature (ECT) sensor – signal malfunction |
Lincoln | Intake air temperature (IAT) sensor 2 -low input |
Mahindra | Engine Speed To Cluster Wire Shorted To Ground |
Mazda | Intake air temperature (IAT) sensor – voltage low |
Mercury | Intake air temperature (IAT) sensor 2 -low input |
Oldsmobile | Engine coolant temperature (ECT) sensor circuit malfunction -voltage low |
Peugeot | Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input |
Pontiac | Engine coolant temperature (ECT)sensor voltage low, intermittent |
Saturn | Engine coolant temperature (ECT) sensor, circuit malfunction, voltage low |
Suzuki | Engine Coolant Temperature Sensor Circuit Intermittent Low Voltage |
Volkswagen | Heated oxygen sensor (HO2S) heater resistance too high |
