P1110
Reading P1110 on your car
P1110 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1110
AudiHeated oxygen sensor (HO2S) 2, Bank 2 - heater short to positive
ChryslerDecreased Engine Performance Condition High IAT Temperature
CitroenIAT Sensor (D/C) Open/Short
DaewooFuel Pump - Stuck
DodgeDecreased Engine Performance Condition High IAT Temperature
GenesisElectronic throttle system (ETS) – malfunction
HyundaiFuel Pump - Stuck On
InfinitiIntake valve timing control solenoid, bank 1 – malfunction
JeepDecreased engine performance -high intake air temperature
KenworthP1110 - Intake air cooling temperature out of range
KiaElectronic throttle system (ETS) – malfunction
MahindraShort Circuit To Ground On Out1 Error For Egr Valve H-Bridge
MazdaIntake air temperature (IAT) sensor (engine)- short/open circuit
NissanCamshaft position (CMP) actuator – bank 1 – circuit malfunction
OpelIntake manifold air control solenoid 1 - circuit malfunction
PeterbiltP1110 - Intake air cooling temperature out of range
PeugeotIAT Sensor (D/C) Open/Short
PorscheOxygen Sensor Heating
RamDecreased engine performance -high intake air temperature
SaabTurbocharger (TC) bypass valve – range/performance problem
SubaruBarometric pressure (BARO) sensor- voltage low
VolkswagenHeated oxygen sensor (HO2S) heater short to positive
We have not gotten around to publishing a technical guide specifically for P1110 yet.
