P1107
Manufacturer Specific Definitions for P1107
Acura | Barometric Pressure Sensor Circuit Low Voltage |
Audi | Heated oxygen sensor (HO2S) 1, Bank 2 - heater short to positive |
Buick | Manifold absolute pressure (MAP) sensor circuit intermittent -voltage low |
Cadillac | Manifold absolute pressure (MAP) sensor-circuit intermittent -voltage low |
Chevrolet | Manifold absolute pressure (MAP) sensor voltage low, intermittent |
Chrysler | BARO Solenoid Performance |
Citroen | Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage |
Daewoo | Manifold absolute pressure (MAP) sensor – intermittent voltage low |
Dodge | BARO Solenoid Performance |
Ford | Dual Alternator Lower Circuit Malfunction |
Genesis | Manifold absolute pressure (MAP) sensor- signal low |
Gmc | Manifold absolute pressure (MAP) sensor voltage low, intermittent |
Gm | Manifold Absolute Pressure Sensor Circuit Intermittent Low Voltage |
Honda | Barometric pressure (BARO) sensor- circuit/voltage low |
Hummer | Manifold absolute pressure (MAP) sensor voltagelow, intermittent |
Hyundai | Air Flow Sensor - High Input |
Isuzu | Manifold absolute pressure (MAP) sensor – circuiUintermittent voltage low |
Jaguar | Manifold absolute pressure (MAP) sensor - circuit low input |
Jeep | BARO Solenoid Performance |
Kia | Manifold absolute pressure (MAP) sensor – signal low |
Lincoln | Dual Alternator Lower Circuit Malfunction |
Mahindra | Over Temperature Error For Egr Valve H-Bridge |
Mercury | Dual Alternator Lower Circuit Malfunction |
Oldsmobile | Manifold absolute pressure (MAP) sensor circuit intermittent -voltage low |
Peugeot | Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage |
Pontiac | Manifold absolute pressure (MAP) sensor voltage low, intermittent |
Porsche | Oxygen Sensor Heating |
Saab | Manifold absolute pressure (MAP) sensor, TC system – open circuit/short to ground |
Saturn | Manifold absolute pressure (MAP) sensor, circuit intermittent, voltage low |
Subaru | Secondary air injection (AIR) diagnosis solenoid – circuit malfunction |
Suzuki | Manifold absolute pressure (MAP) sensor – signal voltage low |
Volkswagen | Heated oxygen sensor (HO2S) heater short to positive |
