P1106
Manufacturer Specific Definitions for P1106
Acura | Barometric Pressure Sensor Range/Performance Problem |
Audi | Heated oxygen sensor (HO2S) 1, Bank 2 - low voltage/air leak |
Buick | Manifold absolute pressure (MAP) sensor circuit intermittent -voltage high |
Cadillac | Manifold absolute pressure (MAP) sensor circuitintermittent -voltage high |
Chevrolet | Manifold absolute pressure (MAP) sensor voltage high, intermittent |
Chrysler | Turbocharger (TC) boost pressure actuator range/performance problem |
Citroen | Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage |
Daewoo | Manifold absolute pressure (MAP) sensor – intermittent voltage high |
Dodge | Main relay -control circuit low |
Ford | Dual alternator lower -malfunction |
Freightliner | Main relay -control circuit low |
Genesis | Manifold absolute pressure (MAP) sensor- signal high |
Gmc | Manifold absolute pressure (MAP) sensor voltage high, intermittent |
Gm | Manifold Absolute Pressure Sensor Circuit Intermittent High Voltage |
Honda | Barometric pressure (BARO) sensor- range/performance problem |
Hummer | Manifold absolute pressure (MAP) sensor voltage high, intermittent |
Hyundai | Air Flow Sensor - Low Input |
Isuzu | Manifold absolute pressure (MAP) sensor – circuiUintermittent voltage high |
Jaguar | Manifold absolute pressure (MAP) sensor - range/performance |
Kenworth | P1106 - Engine Protection System - Derated performance state |
Kia | Manifold absolute pressure (MAP) sensor – signal high |
Lincoln | Manifold Absolute Pressure Sensor Circuit Intermittent High Voltage |
Mahindra | Over Current Error For Egr Valve H-Bridge |
Mercury | Manifold Absolute Pressure Sensor Circuit Intermittent High Voltage |
Oldsmobile | Manifold absolute pressure (MAP) sensor circuit intermittent voltage high |
Peterbilt | P1106 - Engine Protection System - Derated performance state |
Peugeot | Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage |
Pontiac | Manifold absolute pressure (MAP) sensor voltage high, intermittent |
Saab | Manifold absolute pressure (MAP) sensor, TC system – range/performance problem |
Saturn | Manifold absolute pressure (MAP) sensor, circuitintermittent, voltage high |
Subaru | Engine torque control signal 2 – circuit malfunction |
Volkswagen | Heated oxygen sensor (HO2S) low voltage/air leak |
