P1105
BAT Team
Manufacturer Specific Definitions for P1105
AudiHeated oxygen sensor (HO2S) 2, Bank 1 - heater short to positive
BmwFuel pump relay – primary circuit high voltage
BuickSecondary Vacuum Sensor Circuit
CadillacSecondary Vacuum Sensor Circuit
ChevroletSecondary Vacuum Sensor Circuit
Chryslertables Barometric pressure (BARO) read solenoid -circuit malfunction
CitroenDual Alternator Upper Fault
DaewooAir Flow Ctrl V/V Snsr - Pf
DaihatsuBarometric pressure sensor
DodgeFuel pressure regulator control solenoid -circuit malfunction
EagleFuel pressure regulator control solenoid -circuit malfunction
FordDual alternator upper -malfunction
FreightlinerBarometric pressure (BARO) sensor, in ECM -circuit malfunction
GmSecondary Vacuum Sensor Circuit
HyundaiAir Flow Sensor - Abnormal
InfinitiMAP - BARO switching valve - circuit malfunction
KenworthP1105 - Engine Protection System - Approaching Shutdown state
LamborghiniHO2S - 12 heater circuit high voltage
LincolnManifold Absolute Pressure Sensor Circuit Malfunction
MercuryManifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor
MiniDifferential Pressure Sensor Intake Manifold Plausibility
MitsubishiFuel pressure regulator control solenoid – malfunction
NissanMAP/BARO switching valve – circuit malfunction
OpelBarometric pressure (BARO) sensor - circuit malfunction
PeterbiltP1105 - Engine Protection System - Approaching Shutdown state
PeugeotDual Alternator Upper Fault
PorscheOxygen Sensor Heating
RamTurbocharger (TC) boost pressure actuator circuit malfunction
SaabManifold absolute pressure (MAP) sensor, TC   system – performance problem
VolkswagenHeated oxygen sensor (HO2S) heater short to positive
We have not gotten around to publishing a technical guide specifically for P1105 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
