P1104
Manufacturer Specific Definitions for P1104
Audi | HO2S12 Sensor Circuit Voltage Too Low Air Leak |
Bmw | Pedal Position Sensor 2 High Input |
Citroen | MAF Ground Malfunction |
Daewoo | Air Flow Ctrl V/V Pos. Snsr |
Dodge | Turbocharger (TC) wastegate regulating valve -circuit malfunction |
Eagle | Turbocharger (TC) wastegate regulating valve -circuit malfunction |
Hyundai | Air Flow Sensor |
Infiniti | MAP Sensor Low Voltage |
Jaguar | Mass Air Flow Ground Malfunction |
Mini | Differential Pressure Sensor Intake Manifold Plausibility |
Mitsubishi | Turbocharger (TC) wastegate regulating valve – malfunction |
Nissan | Manifold absolute pressure (MAP) sensor – circuit malfunction |
Peugeot | MAF Ground Malfunction |
Saab | Traction control signal – circuit malfunction |
Subaru | Traction control signal – circuit malfunction |
Volkswagen | HO2S12 Sensor Circuit Voltage Too Low Air Leak |
Got Honda Civic 2003, foult code p1104. Have engine light on after diesel filter changing.what could be?
