P1102
Manufacturer Specific Definitions for P1102
Acura | Mass air flow (MAF) sensor - signal higher than expected |
Audi | Heated oxygen sensor (HO2S) 1, Bank 1 - heater short to positive |
Chrysler | Viscous/Cabin Heater Relay Circuit Condition |
Citroen | MAF Sensor In Range But Lower Than Expected |
Daewoo | Map Snsr - Low Input |
Dodge | Viscous/Cabin Heater Relay Circuit Condition |
Ford | Mass Air Flow Sensor In Range But Lower Than Expected |
Hyundai | Manifold Absolute Pressure(MAP) Sensor - Low Input |
Infiniti | Mass air flow (MAF) sensor – performance problem |
Jeep | Viscous/Cabin Heater Relay Circuit Condition |
Kia | Manifold absolute pressure (MAP) sensor – for EGR system – mode 3 |
Lamborghini | HO2S - 11 heater circuit high voltage |
Land Rover | Mass air flow (MAF) sensor/volume air flow (VAF) sensor- voltage low |
Lincoln | Mass Air Flow Sensor In Range But Lower Than Expected |
Mazda | Mass air flow (MAF) sensor – incomparable with TP sensor signal – signal low |
Mercury | Mass Air Flow Sensor In Range But Lower Than Expected |
Mitsubishi | Traction control vent solenoid -circuit malfunction |
Nissan | Mass air flow (MAF) sensor – range/performance problem |
Peugeot | MAF Sensor In Range But Lower Than Expected |
Porsche | Oxygen Sensor Heating |
Saab | MAP/BARO sensor switching valve – circuit malfunction |
Subaru | MAP/BARO sensor switching valve – circuit malfunction |
Volkswagen | Heated oxygen sensor (HO2S) heater short to positive |
