P1100
Manufacturer Specific Definitions for P1100
Audi | HO2S12 Sensor Circuit Voltage Too Low Air Leak |
Bmw | Fuel pump – temperature too high |
Citroen | MAF Sensor Intermittent/Check of all OBDII Systems Not Complete |
Daewoo | Map Snsr Mal |
Ford | Mass Air Flow Sensor Intermittent |
Hyundai | Manifold Absolute Pressure(MAP) Sensor – Malfunction |
Kia | Manifold absolute pressure (MAP) sensor- for EGR system – circuit malfunction |
Land Rover | Mass air flow (MAF) sensor/volume air flow (VAF) sensor- circuit malfunction |
Lexus | Barometric pressure (BARO) sensor – circuit malfunction |
Lincoln | Mass air flow (MAF) sensor -circuit intermittent |
Mazda | Mass air flow (MAF) sensor – intermittent sensing |
Mercury | Mass air flow (MAF) sensor -circuit intermittent |
Mitsubishi | Intake manifold air control actuator position sensor – circuit malfunction |
Opel | Mass air flow (MAF) sensor / manifold absolute pressure (MAP) sensor - implausible signal |
Peugeot | MAF Sensor Intermittent/Check of all OBDII Systems Not Complete |
Saab | Starter signal – circuit malfunction |
Scion | BARO Sensor Circuit Malfunction |
Subaru | Starter signal – circuit malfunction |
Toyota | BARO Sensor Circuit Malfunction |
Volvo | Outside air temperature sensor – range/performance problem |
Volkswagen | HO2S12 Sensor Circuit Voltage Too Low Air Leak |
