P1089
Last Updated 2017-01-16
Manufacturer Specific Definitions for P1089
Dodge | EVAP canister purge system -leak |
Freightliner | EVAP canister purge system -leak |
Infiniti | VVEL Control Shaft Position Sensor Bank 1 Circuit |
Kenworth | P1089 - Detects when rail pressure goes over threshold (APV) in the absence of railp sensor fault |
Nissan | VVEL Control Shaft Position Sensor Bank 1 Circuit |
Peterbilt | P1089 - Detects when rail pressure goes over threshold (APV) in the absence of railp sensor fault |
Saab | Intake manifold air control actuator position sensor, RH – voltage high |
Subaru | Intake manifold air control actuator position sensor, RH – voltage high |
