P1086
Last Updated 2017-01-16
Reading P1086 on your car
P1086 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1086
AudiExhaust Bank 4- Mixture Adaption Range 2 Lower Lean Limit Not Reached
BmwO2 Sensor Heater Control Circuit Bank 2 Sensor 2
KenworthP1086 - Detects if the pressure in the rail does not rise within a given time period after the running of the engine, a keyoff-keyon or the entrace into
MiniFuel Control Mixture Rich Bank 2 Sensor 1
PeterbiltP1086 - Detects if the pressure in the rail does not rise within a given time period after the running of the engine, a keyoff-keyon or the entrace into
SaabIntake manifold air control actuator position sensor, LH – voltage low
SubaruIntake manifold air control actuator position sensor, LH – voltage low
VolkswagenExhaust Bank 4- Mixture Adaption Range 2 Lower Lean Limit Not Reached
We have not gotten around to publishing a technical guide specifically for P1086 yet.
