P1085
Last Updated 2017-01-16
Reading P1085 on your car
P1085 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1085
AudiExhaust Bank 4- Mixture Adaption Range 1 Lower Lean Limit Not Reached
BmwHeated oxygen sensor (HO2S) 2, Bank 2 - heater circuit malfunction
DodgeEVAP canister purge system -leak
FreightlinerEVAP canister purge system -leak
IsuzuHigh Pressure Fuel Pump Performance
MiniFuel Control Mixture Lean Bank 2 Sensor 1
VolkswagenExhaust Bank 4- Mixture Adaption Range 1 Lower Lean Limit Not Reached
We have not gotten around to publishing a technical guide specifically for P1085 yet.
