P1073
Reading P1073 on your car
P1073 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1073
| Make | Fault Location |
| Audi | Mass Air Flow Sensor 2 Signal Too Small |
| Dodge | Intake manifold air control valve -circuit high |
| Freightliner | Intake manifold air control valve -circuit high |
| Volkswagen | Mass Air Flow Sensor 2 Signal Too Small |
We have not gotten around to publishing a technical guide specifically for P1073 yet.
