P1062
Reading P1062 on your car
P1062 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1062
| Make | Fault Location |
| Bmw | O2 Sensor Heater Circuit Low Voltage Bank 2 Sensor 2 |
| Dodge | Coolant Sens Circuit High |
| Kenworth | P1062 - SFS Cruise control Plausibility fault |
| Mini | Valvetronics Power Limitation |
| Peterbilt | P1062 - SFS Cruise control Plausibility fault |
| Saab | Injector 6 – high output |
We have not gotten around to publishing a technical guide specifically for P1062 yet.
Hi . I have the P1062 error on the BMW 118i year of manufacture 2005. Can you tell me what the problem would be if I pray? Thank you in advance.
F-
Well, I’ve never really believed in “faith-healing” cars, but I know there are BMW techs nearly divine in their ability to fix them by the laying of hands. (Sorry, couldn’t resist the joke.)
BMW’s description for DTC P1062 is “VVT limp home request full stroke position not reached bank 1”
Check the connectors for the VVT system (on or near the valve cover?) for solid connection, no water or oil. I’m concerned that this might also reflect an oil pressure problem. Have you been hearing unusual noises in the valve-cover area?
