P1041
Reading P1041 on your car
P1041 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1041
| Make | Fault Location |
| Audi | Injector 2, supply voltage - short circuit |
| Bmw | Mass Or Volume Air Flow Circuit Low Input Bank 2 |
| Dodge | ISA Circuits |
| Mini | Valvetronic Internal Fault |
| Saab | Injector 4 – low output |
| Volvo | Brake Pedal Sensor |
| Volkswagen | Injector 2, supply voltage - short circuit |
We have not gotten around to publishing a technical guide specifically for P1041 yet.
