P1023
BAT Team
Last Updated 2017-01-16
Manufacturer Specific Definitions for P1023
AudiFuel pressure control valve - short to ground
BmwFuel Control Mixture Lean Bank 1 Sensor 1
DodgeIgnition coil, 3 -secondary range/performance
FreightlinerIgnition coil, 3 -secondary range/performance
KenworthP1023 - BPV CAN sensor temperature too high
LexusCamshaft position (CMP) actuator/position sensor, circuit B, bank 2 – malfunction
MiniValvetronic Adjustment Range
MitsubishiValve timing control valve, bank 2 – circuit malfunction
PeterbiltP1023 - BPV CAN sensor temperature too high
ScionCamshaft Position Signal Output B Circuit
ToyotaCamshaft Position Signal Output B Circuit
VolkswagenFuel pressure control valve - short to ground
We have not gotten around to publishing a technical guide specifically for P1023 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
