P1012
Last Updated 2017-01-16
Reading P1012 on your car
P1012 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1012
BmwWT control circuit, bank 1 – high input
BuickExhaust camshaft position (CMP) actuator, bank 1 -incorrect park position
CadillacExhaust camshaft position (CMP) actuator, bank 1 -incorrect park position
ChevroletExhaust camshaft position (CMP) actuator, bank 1-incorrect park position
ChryslerFuel Pump Delivery Pressure Too High
DodgeFuel Pump Delivery Pressure Too High
GmExhaust Camshaft Position Actuator Park Position Bank 1
JeepFuel Pump Delivery Pressure Too High
MiniValvetronic Eccentric Shaft Sensor Reference
PontiacRocker arm oil pressure switch -circuit malfunction
SaabInjector 1 – high output
SaturnExhaust camshaft position (CMP) actuator, bank 1 -incorrect park position
SuzukiExhaust camshaft position (CMP) actuator- incorrect park position – bank 1
ToyotaOil control valve/variable valve lift – LH bank – close malfunction
We have not gotten around to publishing a technical guide specifically for P1012 yet.
