P1000 – OBDII Monitor Testing Not Complete (Ford, Jaguar, Lincoln)
Last Updated 2016-11-14
P1000 | P1000 – OBDII Monitor Testing Not Complete (Ford, Jaguar, Lincoln) (Buy Part On Amazon) | Disconnected battery, insufficient time to reset |
Manufacturer Specific Definitions for P1000
Bmw | VVT control circuit, solenoid loss, bank 1 |
Dodge | Ignition coil, 5 -primary circuit range/performance |
Ford | On Board Diagnostic System Readiness Test Not Complete |
Freightliner | Ignition coil, 5 -primary circuit range/performance |
Jaguar | Engine control module (ECM) - internal error |
Kia | System diagnosis incomplete |
Land Rover | Engine control module (ECM) memory erased – no codes stored |
Lincoln | System readiness test not complete |
Mazda | OBD-11 monitor testing not complete |
Mercedes-Benz | Transmission shift lever control module- defective |
Mercury | System readiness test not complete |
Mini | Secondary AIR Delivery |
Volvo | Engine control module (ECM) – circuit malfunction |
What Does Code P1000 Mean?
OBD II code P1000 is generally defined as “OBDII Monitor Testing Not Complete”, and is set either when the OBD II system has not completed a full self-diagnostic cycle, or when there are conditions present that prevent the system from running self-diagnostic tests. Note that while code P1000 is a manufacturer-specific code, the actual definition assigned to the code varies somewhat between manufacturers. Below are some examples of different definitions for this code-
- P1000 – Jaguar: “Engine control module (ECM) – internal error”
- P1000 – Land Rover: “Engine control module (ECM) memory erased – no codes stored”
- P1000- Mazda: “OBDII Drive Cycle Malfunction”
“Monitor testing” refers to the battery of tests the OBD II system needs to complete to confirm that the emission control system on the application is fully functional. However, when dealing with P1000 it is important to define the definition: in automotive diagnostics parlance, “monitor” refers to the circuits involved in testing each function, component, or sub-system of the emission control system.
The primary function of the self-diagnostic capability is two-fold:
To detect if any emission control system components have been tampered with, removed, bypassed, modified, or altered in any way to ensure that all components are present and are working as designed on the one hand, and
to determine whether the vehicles’ OBD II system has completed all required tests, on the other.
Note that code P1000 does not identify, or indicate faults per se; all its presence indicates is that the self-diagnostic procedure is not complete, or cannot be completed. Also, note that some functions are continuously monitored by the OBD II system (while the vehicle is driven) while others require very specific conditions to be met before a test can be run, or completed by the OBD II system.
The latter group of tests is commonly referred to as “non-continuous monitors”. This group of tests is fundamentally different from continuous monitors, in the sense that environmental factors often determine whether a test can be run or not. One example of this is a long spell of cold weather that can influence the working of the EVAP system especially on some Ford products, although cold weather combined with high altitudes can influence other makes as well.
Readiness monitors explained
NOTE: Due to the differences in the design specifics of emission control systems of different applications, it is not possible to provide exact, specific information for all applications. The information below is therefore not exhaustive, or definitive, and it is presented here for general informational purposes only. Always refer to the relevant manual for the application being worked on for detailed information pertaining to code P1000.
Nonetheless, the short description of various types of monitors below should suffice to provide a general sense of the types of self-diagnostic tests performed by a typical OBD II system on a modern vehicle.
Continuous monitors:
The tests below are carried out on a continuous basis as the vehicle is driven, since failures or defects in these systems have a direct bearing on combustion, and hence emissions-
- Misfire detection
- Fuel system
Both these tests involve comprehensive checking and monitoring of all components in the systems.
Non-continuous monitors
NOTE: Due to the major differences in the operating principles of gasoline and diesel engines, non-continuous monitors are different for each type of engine.
Non-continuous monitors for gasoline engines:
- Catalytic converter function
- Heated catalyst operation
- Leak detection in the EVAP system
- Secondary air injection system function
- Oxygen sensor function, which includes checking the functioning of the heated element in the sensor
- Exhaust gas recirculation system function
- VVT/VCT system operation
Non-continuous monitors for diesel engines:
- NMHC (Non-methane Hydrocarbon) catalyst function
- SCR (Selective Catalytic Reduction) effectiveness
- Forced induction pressure
- Exhaust gas temperature
- DPF (Diesel Particulate Filter) condition or state
- VVT/VCS system operation
What are the common causes of code P1000?
In the majority of cases, P1000 is set either when the battery is disconnected, or when not sufficient time has passed for the OBD II system to reset fully after clearing other codes without having resolved them.
Note however that in many cases, the OBD II system requires a full drive cycle (or two cycles in some cases) to fully reset even after emission control-related trouble codes had been resolved successfully. It is also possible to find code P1000 on brand new vehicles that have not yet completed the required drive cycle(s) to clear P1000 automatically.
What are the symptoms of code P1000?
Code P1000 will rarely exhibit symptoms other than a stored code and perhaps an illuminated warning light. However, where codes or conditions exist that prevent the OBD system from running or completing self-diagnostic tests, those codes or conditions might produce drivability issues and/or other symptoms, and they must therefore be resolved before attempting to clear P1000. Note that P1000 can generally not be cleared before codes and/and conditions that brought up P1000 are resolved.
How do you troubleshoot code P1000?
Since P1000 is not a fault code per se, there are no specific or even generalized diagnostic and repair procedures for it. However, in the vast majority of cases where P1000 is present, resolving it could be as simple as completing a drive cycle as per the manufacturer’s definition of a drive cycle. Consult the manual for the application being worked on for detailed information of what constitutes a drive cycle for that particular application.
Nonetheless, some cures require real work, time, and trouble and while it is not possible to list all possible cures here, the table below provides a general overview of what might be required to resolve P1000. Note that this table lists possible causes of P1000 on both gasoline and diesel engines. Also, take particular note of the fact that the table below merely lists the parameters used by the OBD II system when checking each component or system during self-diagnostic resting. The actual value, or relevance of each parameter to code P1000 listed here must be researched before drawing any conclusions as to the most probable cause of P1000.
System/Component | Parameters Monitored |
Fuel system | Fuel system pressure control Injection quantity Injection timing Feedback control |
Misfires | Detection of continuous, or random misfires Determination of % of misfires / 1000 engine cycles (2013 and later engines) |
EGR | Low flow High flow Slow response EGR cooler operation EGR catalyst performance Feedback control |
Boost pressure | Detection of under-boost/over-boost conditions Slow response Monitoring of charge air temperature Feedback control |
NMHC catalyst | Conversion efficiency DPF heating SCR feedgas (e.g., NO2) Provide post DPF NMHC clean-up Provide ammonia clean-up Catalyst aging |
SCR NOx catalyst | Conversion efficiency: SCR reductant delivery performance Tank level, fuel quality, and injection feedback control Catalyst aging |
NOx adsorber | NOx absorber capability Desorption function Fuel delivery Feedback control |
DPF | Filtering performance Regeneration frequency NMHC conversion Incomplete regeneration Missing substrate Active regeneration Fuel delivery Feedback control |
Exhaust gas sensors | For air-fuel ratio and NOx sensors: Performance, Circuit faults, Feedback, and monitoring capability Other exhaust gas sensors Sensor heater function Sensor heater circuit faults |
VVT | Target error Slow response |
Cooling system/ CCV | Thermostat ECT sensor circuit faults ECT sensor circuit out-of-range ECT sensor circuit rationality faults System integrity |
Comprehensive component monitoring | |
Cold start emission reduction strategy | |
Other emission control system monitoring | |
Codes Related to P1000
There are no “related” codes, except in the sense that the presence of one or more other codes and/or fault conditions along with P1000 could prevent the execution of self-diagnostic tests.
I got 2004 f150 4.6 and recently my transmission act up now it reverses but no drive on any gear
I plug in obd this what shows
Fault log report generated by Torque for Android
Vehicle VIN: 1FTRX12W64NA56401
Vehicle Manufacturer: Ford
Vehicle Calibration ID: OKAP9H4.HEX
Current Fault Log
ECU reports no current faults
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
B2659: null
P1000: OBD-II Monitor Testing Incomplete
U1900: null
U1950: null
End of report.
And beginning gave out dashboard shows trans.fault
Please help need contact me email is [email protected]
As you can see I do mobile services and need for work ??
Pierde potencia, Dtc p208
I have a 03 Mustang GT 4.6 2 valve and I’m throwing a P1151 code. Lack of of Upstream heated oxygen sensor switch. I don’t know why it’s throwing this code it’s Looney my motor out. I clear the code and it runs fine for a while sometimes hours in the code comes back on and it sucks meaning me out again. Check the 02 that’s fine. I can’t seem to find a leak anywhere. Can anybody help me out…
Also is throwing p1000 code now.
